Je n’ai pas Office 64 bits pour tester la première partie mais pour le 32 bits à partir de Office 2010 (VBA7 et pas win64) ça devrais ressembler à ça :
Option Explicit
#If vb7 Then
#If Win64 Then
Private Declare PtrSafe Function CallNextHookEx Lib "user32" (ByVal hHook As LongLong, ByVal nCode As LongLong, ByVal wParam As LongLong, lParam As Any) As LongLong
Private Declare PtrSafe Function GetModuleHandle Lib "kernel32" Alias "GetModuleHandleA" (ByVal lpModuleName As String) As LongLong
Private Declare PtrSafe Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" (ByVal idHook As LongLong, ByVal lpFn As LongLong, ByVal hmod As LongLong, ByVal dwThreadId As LongLong) As LongLong
Private Declare PtrSafe Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As LongLong) As LongLong
Private Declare PtrSafe Function SendDlgItemMessage Lib "user32" Alias "SendDlgItemMessageA" (ByVal hDlg As LongLong, ByVal nIDDlgItem As LongLong, ByVal wMsg As LongLong, ByVal wParam As LongLong, ByVal lParam As LongLong) As LongLong
Private Declare PtrSafe Function GetClassName Lib "user32" Alias "GetClassNameA" (ByVal hwnd As LongLong, ByVal lpClassName As String, ByVal nMaxCount As LongLong) As LongLong
Private Declare PtrSafe Function GetCurrentThreadId Lib "kernel32" () As LongLong
Private hHook As LongLong
#Else
Private Declare PtrSafe Function CallNextHookEx Lib "user32" (ByVal hHook As LongPtr, ByVal nCode As Long, ByVal wParam As LongPtr, lParam As Any) As LongPtr
Private Declare PtrSafe Function GetModuleHandle Lib "kernel32" Alias "GetModuleHandleA" (ByVal lpModuleName As String) As LongPtr
Private Declare PtrSafe Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" (ByVal idHook As Long, ByVal lpFn As LongPtr, ByVal hmod As LongPtr, ByVal dwThreadId As Long) As LongPtr
Private Declare PtrSafe Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As LongPtr) As Long
Private Declare PtrSafe Function SendDlgItemMessage Lib "user32" Alias "SendDlgItemMessageA" (ByVal hDlg As LongPtr, ByVal nIDDlgItem As Long, ByVal wMsg As Long, ByVal wParam As LongPtr, ByVal lParam As LongPtr) As LongPtr
Private Declare PtrSafe Function GetClassName Lib "user32" Alias "GetClassNameA" (ByVal hwnd As LongPtr, ByVal lpClassName As String, ByVal nMaxCount As Long) As Long
Private hHook As LongPtr
#End If
#Else
Private Declare Function CallNextHookEx Lib "user32" (ByVal hHook As Long, ByVal nCode As Long, ByVal wParam As Long, lParam As Any) As Long
Private Declare Function GetModuleHandle Lib "kernel32" Alias "GetModuleHandleA" (ByVal lpModuleName As String) As Long
Private Declare Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" (ByVal idHook As Long, ByVal lpFn As Long, ByVal hmod As Long, ByVal dwThreadId As Long) As Long
Private Declare Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As Long) As Long
Private Declare Function SendDlgItemMessage Lib "user32" Alias "SendDlgItemMessageA" (ByVal hDlg As Long, ByVal nIDDlgItem As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Private Declare Function GetClassName Lib "user32" Alias "GetClassNameA" (ByVal hwnd As Long, ByVal lpClassName As String, ByVal nMaxCount As Long) As Long
Private Declare Function GetCurrentThreadId Lib "kernel32" () As Long
#End If
Private Const EM_SETPASSWORDCHAR = &HCC
Private Const WH_CBT = 5
Private Const HCBT_ACTIVATE = 5
Private Const HC_ACTION = 0
Dim RetVal
Public Function NewProc(ByVal lngCode As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Dim strClassName As String, lngBuffer As LongLong
If lngCode < HC_ACTION Then
NewProc = CallNextHookEx(hHook, lngCode, wParam, lParam)
Exit Function
strClassName = String$(256, " ")
lngBuffer = 255
If lngCode = HCBT_ACTIVATE Then
RetVal = GetClassName(wParam, strClassName, lngBuffer)
If Left$(strClassName, RetVal) = "#32770" Then
SendDlgItemMessage wParam, &H1324, EM_SETPASSWORDCHAR, Asc("*"), &H0
CallNextHookEx hHook, lngCode, wParam, lParam
End Function
Public Function InputBoxDK(Prompt, Optional Title, Optional Default, Optional XPos, Optional YPos, Optional HelpFile, Optional Context) As String
Dim lngModHwnd As LongLong, lngThreadID As LongLong
lngThreadID = GetCurrentThreadId
lngModHwnd = GetModuleHandle(vbNullString)
hHook = SetWindowsHookEx(WH_CBT, AddressOf NewProc, lngModHwnd, lngThreadID)
InputBoxDK = InputBox(Prompt, Title, Default, XPos, YPos, HelpFile, Context)
UnhookWindowsHookEx hHook
End Function
Ceci dit, le fichier que tu as joint est bourré d’erreur lors de la compilation à cause de l’absence de certains contrôles dans les formulaires …
