Je te met la ligne de code de ma macro, ci dessous :
Sub Ajouter_fiche()
Ajouter_fiche Macro
Sheets("Recueil données").Select
Rows("2:2").Select
Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
Selection.Font.Bold = False
With Selection.Interior
.Pattern = xlNone
.TintAndShade = 0
.PatternTintAndShade = 0
Sheets("Formulaire").Select
Range("A2").Select
Selection.Copy
Range("A2").Select
:=False, Transpose:=False
Range("B2").Select
Selection.Copy
Range("B2").Select
Range("C2").Select
Selection.Copy
Range("C2").Select
Range("D2").Select
Range("D2").Select
Selection.Copy
Range("D2").Select
Range("E2").Select
Range("E2").Select
Selection.Copy
Range("F2").Select
Selection.Copy
Range("F2").Select
Range("G2").Select
Selection.Copy
Range("G2").Select
Range("H2").Select
Range("H2").Select
Selection.Copy
ActiveSheet.Paste
Range("I2").Select
Selection.Copy
Range("I2").Select
Range("J2").Select
Selection.Copy
Range("J2").Select
Range("M2").Select
Selection.Copy
Range("L2").Select
Selection.Copy
Range("L2").Select
Range("K2").Select
Selection.Copy
Range("K2").Select
ActiveSheet.Paste
Range("M2").Select
Range("M2").Select
Selection.Copy
Range("T2").Select
Range("N2").Select
Selection.Copy
Range("N2").Select
Range("O2").Select
Selection.Copy
Range("O2").Select
Range("P2").Select
Selection.Copy
Range("P2").Select
Range("R2").Select
Selection.Copy
Range("R2").Select
Range("S2").Select
Selection.Copy
Range("S2").Select
Range("T2").Select
Range("T2").Select
Selection.Copy
Range("W2").Select
Range("U2").Select
Selection.Copy
Range("U2").Select
Range("V2").Select
Selection.Copy
Range("V2").Select
ActiveSheet.Paste
Columns("V:V").Select
Selection.NumberFormat = "h:mm;@"
Range("W2").Select
Range("W2").Select
Selection.Copy
Range("X2").Select
Range("X2").Select
Selection.Copy
Range("Y2").Select
Selection.Copy
Range("Y2").Select
Range("Z2").Select
Selection.Copy
Range("Z2").Select
ActiveSheet.Paste
Range("AA2").Select
Selection.Copy
Range("AA2").Select
Range("AB2").Select
Selection.Copy
Range("AB2").Select
Range("AC2").Select
Selection.Copy
Range("AC2").Select
Range("AD2").Select
Selection.Copy
Range("AD2").Select
Range("AE2").Select
Selection.Copy
Range("AE2").Select
Range("A5,C5,A9,D9,E9,F9,G9").Select
Range("G9").Activate
Selection.ClearContents
Range( _
"C14,E14,F14,G14,C17,E17,F17,G17,C20,E20,F20,G20,C23,E23,F23,G23,C26,E26,F26,G26,C29,E29,G29,F32" _
).Select
Range("G29").Activate
Range("A5").Select
Elle est parfaitement fonctionnelle pour la retranscription des données, je commence à paramétrer la validation des données en ce moment
En ce qui concerne la pile et le jouet je reconnais être débutant en codage, pas de soucis ^^
Pour ce qui est du fichier excel tu le trouveras ici : https://1drv.ms/x/s!AnxYuYY8nG6Dga8p-qBPhqv3luxwdw?e=IEqnTd
Merci de ce que tu pourras m’apporter
