bonjour
esi il possible svp de reduire ce code suivant :
Sub nnnn()
Dim a, b(4) As Integer, i As Integer, f As Integer, m As Integer, L As Integer, dlig As Integer
Columns("H:M").ClearContents
a = Worksheets("NEW_VB_config").Range("o2:o12") 'nom des 11 feuilles
For i = 2 To 100
'For L = 1 To 6
For f = 1 To 11 'boucle sur les feuilles
If a(f, 1) <> "" Then
dlig = Range("H65536").End(xlUp).Row + 1
With Worksheets(a(f, 1))
If .Range("ao" & i).Value <> "" Then
x = Left(.Range("ao" & i), 1)
y = Left(.Range("ao" & i), 2)
y1 = Right(y, 1)
y2 = Left(.Range("ao" & i), 3)
y22 = Right(y2, 1)
y3 = Right(.Range("ao" & i), 1)
'For m = 1 To 4
'b(m) = Mid(.Range("ao" & i), m, 1)
'tab1
' Q
If ActiveCell.Activate And .Range("a" & i).Value = ActiveSheet.Range("a1") Then
If ActiveCell.Row = 2 And ActiveCell.Column = 2 And x = 1 Then
ActiveSheet.Cells(dlig, 8) = .Cells(i, 1)
ActiveSheet.Cells(dlig, 9) = .Cells(i, 2)
ActiveSheet.Cells(dlig, 10) = .Cells(i, 3)
ActiveSheet.Cells(dlig, 11) = .Cells(i, 4)
ActiveSheet.Cells(dlig, 12) = .Cells(i, 5)
ActiveSheet.Cells(dlig, 13) = .Cells(i, 6)
ElseIf ActiveCell.Row = 3 And ActiveCell.Column = 2 And x = 2 Then
ElseIf ActiveCell.Row = 4 And ActiveCell.Column = 2 And x = 3 Then
ElseIf ActiveCell.Row = 5 And ActiveCell.Column = 2 And x = 4 Then
'C
ElseIf ActiveCell.Row = 2 And ActiveCell.Column = 3 And y1 = 1 Then
ElseIf ActiveCell.Row = 3 And ActiveCell.Column = 3 And y1 = 2 Then
ElseIf ActiveCell.Row = 4 And ActiveCell.Column = 3 And y1 = 3 Then
ElseIf ActiveCell.Row = 5 And ActiveCell.Column = 3 And y1 = 4 Then
'D
ElseIf ActiveCell.Row = 2 And ActiveCell.Column = 4 And y22 = 1 Then
ElseIf ActiveCell.Row = 3 And ActiveCell.Column = 4 And y22 = 2 Then
ElseIf ActiveCell.Row = 4 And ActiveCell.Column = 4 And y22 = 3 Then
ElseIf ActiveCell.Row = 5 And ActiveCell.Column = 4 And y22 = 4 Then
'P
ElseIf ActiveCell.Row = 2 And ActiveCell.Column = 5 And y3 = 1 Then
ElseIf ActiveCell.Row = 3 And ActiveCell.Column = 5 And y3 = 2 Then
ElseIf ActiveCell.Row = 4 And ActiveCell.Column = 5 And y3 = 3 Then
ElseIf ActiveCell.Row = 5 And ActiveCell.Column = 5 And y3 = 4 Then
'tab2
'Q
If ActiveCell.Activate And .Range("a" & i).Value = ActiveSheet.Range("a7").Value Then
If ActiveCell.Row = 8 And ActiveCell.Column = 2 And x = 1 Then
ElseIf ActiveCell.Row = 9 And ActiveCell.Column = 2 And x = 2 Then
ElseIf ActiveCell.Row = 10 And ActiveCell.Column = 2 And x = 3 Then
ElseIf ActiveCell.Row = 11 And ActiveCell.Column = 2 And x = 4 Then
'C
ElseIf ActiveCell.Row = 8 And ActiveCell.Column = 3 And y1 = 1 Then
ElseIf ActiveCell.Row = 9 And ActiveCell.Column = 3 And y1 = 2 Then
ElseIf ActiveCell.Row = 10 And ActiveCell.Column = 3 And y1 = 3 Then
ElseIf ActiveCell.Row = 11 And ActiveCell.Column = 3 And y1 = 4 Then
'D
ElseIf ActiveCell.Row = 8 And ActiveCell.Column = 4 And y22 = 1 Then
ElseIf ActiveCell.Row = 9 And ActiveCell.Column = 4 And y22 = 2 Then
ElseIf ActiveCell.Row = 10 And ActiveCell.Column = 4 And y22 = 3 Then
ElseIf ActiveCell.Row = 11 And ActiveCell.Column = 4 And y22 = 4 Then
'P
ElseIf ActiveCell.Row = 8 And ActiveCell.Column = 5 And y3 = 1 Then
ElseIf ActiveCell.Row = 9 And ActiveCell.Column = 5 And y3 = 2 Then
ElseIf ActiveCell.Row = 10 And ActiveCell.Column = 5 And y3 = 3 Then
ElseIf ActiveCell.Row = 11 And ActiveCell.Column = 5 And y3 = 4 Then
'tab3
'Q
If ActiveCell.Activate And .Range("a" & i).Value = ActiveSheet.Range("a13").Value Then
If ActiveCell.Row = 14 And ActiveCell.Column = 2 And x = 1 Then
ElseIf ActiveCell.Row = 15 And ActiveCell.Column = 2 And x = 2 Then
ElseIf ActiveCell.Row = 16 And ActiveCell.Column = 2 And x = 3 Then
ElseIf ActiveCell.Row = 17 And ActiveCell.Column = 2 And x = 4 Then
'C
ElseIf ActiveCell.Row = 14 And ActiveCell.Column = 3 And y1 = 1 Then
ElseIf ActiveCell.Row = 15 And ActiveCell.Column = 3 And y1 = 2 Then
ElseIf ActiveCell.Row = 16 And ActiveCell.Column = 3 And y1 = 3 Then
ElseIf ActiveCell.Row = 17 And ActiveCell.Column = 3 And y1 = 4 Then
'D
ElseIf ActiveCell.Row = 14 And ActiveCell.Column = 4 And y22 = 1 Then
ElseIf ActiveCell.Row = 15 And ActiveCell.Column = 4 And y22 = 2 Then
ElseIf ActiveCell.Row = 16 And ActiveCell.Column = 4 And y22 = 3 Then
ElseIf ActiveCell.Row = 17 And ActiveCell.Column = 4 And y22 = 4 Then
'P
ElseIf ActiveCell.Row = 14 And ActiveCell.Column = 5 And y3 = 1 Then
ElseIf ActiveCell.Row = 15 And ActiveCell.Column = 5 And y3 = 2 Then
ElseIf ActiveCell.Row = 16 And ActiveCell.Column = 5 And y3 = 3 Then
ElseIf ActiveCell.Row = 17 And ActiveCell.Column = 5 And y3 = 4 Then
' Next m
Next f
'Next L
Next i
